- Feb 4, 1999
Here's a link to a picture of that tanto I;ve been fooling with. The scan turned out pretty good, at least!
One thing before you click the link...Geocities has an annoying policy that you can't just directly link to a picture. So, if you click that link, you'll go to a "page unavailable" thing. To see the picture, open a new window in your browser, enter the address you see below in the address bar, and it should take you to the pic. Worked for me, at least.
http://www.geocities.com/chiro75/tanto.jpg
Here's everything that's been done:
1st HT- coated in clay, tried to get to critical temp, thought I made it, quenched in hot oil, and tempered @ 375 (it's 1084, by the way). Then refinished and etched in ferric chloride. Then I quickly found out that the whole thing, with the exception of the two inches around the tip, was soft.
So, I did it all again, this time heating in a one brick forge. The end result was that the proximal portion of the blade that was previously soft was now hard, but the part that was hardened before, was now soft! Obviously I need to anneal the thing and start over. Anyway, you can see the hardened zone very well on this picture. This is after finishing the knife again, etching lightly and steel wooling. The finish on this knife is great by my standards, but it's still unusable! If you look really closely you can see where the original temper line sort of took toward the tip. It's very faint. The other thing, that I don't think you can see on the picture, is that throughout the blade there are little spots of shiny (versus the sort of matte finish the etching creates) bits. I don't know if these are areas that hardened, too, or if I burned out the carbon from these areas or what. Weird. Anyway, somebody offered to try to rehab this thing, so I'm going to give it a shot and see what happens. I'm very pleased with the way the thing turned out. If I could get a decent HT on it I'd be set!
