Working around the shop with my Large Serrated Reg....View attachment 1620010
The original owner lives in Europe. Knife laws precipitated his removing the studs and filling the gap with glowy stuff…hopefully not tritiumWhat happened to the thumb lug?
I just horse traded into a Large Regular Sebenza. It only came with the box and a small allen wrench. No other paperwork or kit. So I have no idea when it was made or what kind of steel the blade is. The box has a label with "Large Sebenza" on one end. The top of the box has a sticker with:
1984-1997
13 Years of Excellence
Chris Reeve Knives
I took it apart to clean it and there were no stampings inside of the handles, but there was a faint "31" etched into the side of the blade near the pivot hole.
The edges of the the handles have small grooves in them that go from front to the back.
It definitely is a "User" as it has some scuff and scratches on it, but other than that, it is in beautiful shape.
Definitely looks like it has the belly of a BG42 blade. I highly suspect it's a 96 BG42 and the 31 was done by someone else. No way CRK would put a mark on the steel where the washer would come into contact.Here is a better pic of the blade:
It does have solid washers. I sent in a request for info to CR Knives and this is the response I got:
"That is a Large Sebenza Regular in either a BG-42 or S30V blade steel. They were produced from 1996-2008. If it doesn't have its original birth card I couldn't give you the actual birth date. S30V blades will have an S on the blade above the pivot but you would have to remove the blade from the knife to see that."
So, I took it apart again, but there was no "S" on the blade, just the number "31". So I am guessing mine has a BG-42 blade then. I'll check and see about re-issuing a Birth date card.
Thanks!
the number 13 on the box indicates that this is 1997. With a high probability, we can say that BG42 steel. More accurate information can be obtained by doing chemical analysis. The number 31 does not look original, perhaps the previous owner of the knife did it.I just horse traded into a Large Regular Sebenza. It only came with the box and a small allen wrench. No other paperwork or kit. So I have no idea when it was made or what kind of steel the blade is. The box has a label with "Large Sebenza" on one end. The top of the box has a sticker with:
1984-1997
Chris Reeve Knives
