- May 16, 2016
Odog27 has the right idea. It will work if nothing goes wrong. If something does go wrong, which is more likely with a pigtail, then not only will the kiln be toast before the breaker pops but there's a good chance the wires will burn up and catch fire with a 50A breaker. That wire is rated for 20A, if the fault is causing the kiln to push 45A the breaker will not trip but make that 20A wire catch fire and burn. I would say change the breaker or run a sub panel and get the proper wiring. Just my two cents. Best of luck and I hope it all works out. Let us know!
