I have a 40 lb tank for my forge, and I filled it about a month ago when it was very cold (as in below zero outside). When I hooked it up the my forge, it worked for a few minutes and then the forge started belching out big yellow flames from both ends without the light blue flame I normally see. The propane line and regulator were frosted, and the flames took a while to die down after I closed the tank and regulator. I assumed that because I had filled it when it was cold (when the propane had lower pressure) and then used in a warm garage, the pressure had rose significantly and caused problems. So, I switched to a smaller 20lb tank and have used that since. In the meantime, I have used the 40 lb tank with the grill, and haven’t experienced any issues.
Today I figured that enough propane had been used for the pressure to go down enough to work with the forge again. Well, it worked fine for about 5-10 minutes before it did the same thing as before: 2 foot yellow flames from either end of the forge, a lack of the normal quiet roaring, and no light blue flame. The propane hose and regulator had iced over again, just like before. A 20lb tank still works fine with it, so I don’t think its a problem with the regulator. Is the tank still too full?
