You are probably going to get a variety of answers....i just received a BK16 and I would like to strip and patina it. My question is the patient under the scales enough to protect from rust or should this area be protected with something. If it should be protected what does everyone use.
Chuck
Thanks all for the advice, I think I will strip the whole knife and patina. What is a good forced patina method, or just let it patina with use and age.
azwelke really nice kydex you do, I will be looking in to these.
Chuck
Followed you link, that’s a nice looking 10 & 11 you got there.I just did my 10 and 11. Stripped them all the way down, and patinad with mustard. Taped up the blade side , attached scales removed tape around scales, removed scales, Got some Rust-Oleum Automotive clear coat spray paint, and sprayed a couple of coats over the handle sides. Came out perfect, and the Rust- oleum prevents the rust. I'll still check occasionally to see if there are any issues. Rubbed mineral oil on the blade.
https://bladeforums.com/threads/bec...ication-thread.1224943/page-112#post-18856410
I’ll have to look for examples of scotch brighter grind areas, that sounds like a nice contrast.1. Handles off
2. Degrease the whole knife
3. Use anything acidic on it (lots of things work - Lemon Juice, strong Instant Coffee, etc.) and let sit for a bit until you see it darkening or it dries
4. Wash off with water and a rag
5. This is when I use Scotchbrite on the Grind area, rubbing in a spine to edge direction to polish off the etching from the acid
6. Wipe clean and re-apply etching solution and leave to darken/dry
7. Wash off with a rag and water
8. Scotchbrite the blade grind portion, again, and then spray it all with Windex to neutralize the acid.
9. Rinse, dry, and rub it down with a little oil.
The smoother the surface, the less pits/grooves there are for corrosion to start.
Smooth or polished 1095 just won't rust that easily. Trust me
** Wiping acidic stuff off of your blade after contact prevents pitting. That includes Sweat, Beer, Alien Blood, etc.
Have fun and re-etch your blade once in a while!
