- Nov 29, 1998
I just received a Buck Strider tanto folder and I have a question about the leading tanto edge. Is the leading edge just intended for piercing and not cutting? It seems much too thick and abrupt an angle to be used for cutting, at least mine does. I am used to the Benchmade CQC7 tanto which has a thinner profile and bevel ground. The leading edge on that knife is useful for cutting as well as facilitating a piercing blow.
The primary cutting edge is fine after reprofiling with my Lansky extra course and working down to a finer grit stone.
Has anyone taken the bevel down on the leading edge and if so what did you use to remove that much metal?
thanks
John
thanks
John
