- Nov 9, 1999
OK, t'other day I get to thinking about Sais and what their intended use was. The most confusing parts are: (1) Any Sai you see today will be completely blunt for some odd reason. (2) If you watch some one using a sai in a movie or on TV you will always see them putting their first two fingers over the guard. Now, nobody can argue with me when I say that it would make a much better weapon if you ground a sharp point on the end. No you can't, so don't even try. I'm not listening. Furthermore it seems to me that if they were used properly, the 'guard' should be used for catching an opponents weapon, which would not be wise if you had your fingers there.
So I ended up doing a 'net search and found conflicting stories of it's origin and use. One theory states that it evolved from a tool for planting rice. The other claims that it was a hair pin many years ago. Also, one states that it WAS sharpened in days past while the other claims that it was always blunt because it was a defensive tool and fairly worthless as an attaking weapon. I disagree here as I'm not blind. It seems to me to be a very effective offensive weapon. You've got the upswept guard (excuse the lack of proper terms) that looks very good for catching and turning blows from almost any weapon and, provided the points were sharp, you could deliver mortal wounds to the chest and neck.
So can anyone help me out here. You martial artists out there, How are they used today? Are the blunt ends only for safety while training? Do you in fact put your fingers over 'guard' thus making it worthless for deflecting blows?
And finally, where could I buy a decent pair? If a decent pair cannot be had, I'll fire up the forge and make some. It should be fairly simple other than welding the 'guard'. Have to work on my welding.
Thanks.
Thanks.
