- Jun 4, 2010
A quick write up / comparison of a couple of combination diamond stones.
The Ultrasharp 300/1200
DMD 400/1200
and the DMT duosharp C/F for a baseline
Since the DMT is so well known I'm going to focus on the other two. My version of the DMD is a branded unit from Foss, a speedskate mfg and the stone was marketed for such. Non-branded versions are on big river for about half what I paid.
I tested these with a high carbon chisel and an EKA 12c27 knife.
In order of coarseness:
Ultrasharp 300
DMD 400
DMT C
Ultrasharp 1200
DMT F
DMD 1200
Ultrasharp 300 is fastest by a clear margin, scratch pattern is more aggressive than the other two but not by much. Probably runs dead between a DMT XC and C. It seems to have a very good bond to the plate. Flattened out the back of the chisel and reset the face in minutes. It likewise reprofiled the 12c in half the time it took on the DMD or DMT.
DMD 400 was about as fast as the DMT, finish only a little more coarse then DMT C.
I didn't test the chisel edge at this point, but all three knife edges could shave armhair and shearcut crossgrain fine catalog paper. Performance was in a line with the scratch pattern, but all three made a clean edge with little fussing.
Off the Ultrasharp 1200 the chisel could just make clean passes across endgrain pine. Not to a wet look, but close. With a handful of passes on a washboard strop it could pass the endgrain pine probably better than it came from the factory. Passes along the gran yielded nice thin curls.
DMT F had similar performance, maybe a touch more refined.
The DMD 1200 was a bit more refined yet, still not passing the "wet looking endgrain" test off the stone but with a bit of stropping was able to do so. Edge finish is probably just shy of the DMT EF.
Performance on the 12c was also similar - all edges could shave armhair and now crosscut catalog paper without needing to shear. DMD was the quietest doing so, but not to any large degree.The Ultrasharp was fastest again, producing a somewhat less refined edge but doing so much more rapidly than the other two plates - a good trade off.
All in all am liking the Ultrasharp combi stone and it will likely take the place of or be used interchangeably with the other two stones in applications where the edge finish is going to be part of a longer progression. The speed is a big factor - it is faster than the DMT is faster than the DMD. It is the only one of the three I could consider using for chisels or plane irons. On knives one could set up for a microbevel in less time than the other two stones and at a finish level where the differences will be inconsequential.
The DMD stone is a good value too, especially for the $. Even overpaying it is the cheapest of the three. I suspect it will not have the longevity of the DMT or Ultrasharp but seems to be holding up well so far. To date has seen more use than the other stones and does not appear to be suffering any ill effects. It may be relegated to a travel stone, as it is the lightest of the bunch - even lighter than the duosharp. I was able to stash a small piece of compound in the base as an added bonus.
DMD 400/1200
Ultrasharp 300
DMD 400
DMT C
Ultrasharp 1200
DMT F
DMD 1200
