yup.. I pretty much winging it, free handing
it's the same a trying to keep the grinds the same on both
side of the blade. but more like 3 D The slack belt can work for you
with the feel for it..
I do the profile first
then work the sides down going from one side to
the other keeping them as uniform as I can, and at the same time
contouring with the slack belt, rotating the handle.
once I get the sides where I want them,
I'll knock off the corners (edges) and then put the knife in the vise
then I strip up some sand paper about 1/2"x11" from 320 grit to 400
I use mostly the 400 grit.
then I start rounding the profile with one or the other up in the vice
the edge or the back bone then do the other. I use a chain saw file
to contour the finger guard aria then the sanding with
strips at about 1/4"x 11" then
hand sand all over to a fine grit ( grit depending on what I'm
working with.)then I buff (again depending on what I'm
working with for type of rouge )that's it in a nut shell for me..
the strips wrapped over the whole back or bottom will round out
the roughed shape very well.
pulling the strip ends like a stropping motion, if I explained it right.
kind of like buffing shoes with a rag
