I came across an old Randall model 3 I think, looking over the knife I have noticed a couple things that I am curious about and I was hoping that maybe an expert could chime in. Two of the leather washers on the handle are quite a bit thicker than the others, like 3/8" compared to 3/16", and the spacers above the pommel aren't perfectly horizontal, in other words the spacers are about a 16th lower on the right side of the handle compared to the left. This is an old knife and has seen some use. The leather was very dry and dirty before I cleaned it up and applied some leather conditioner. I am wondering if it was common for Randall made knives to use different thickness washers? Could the spacers on the pommel end have shifted over the years if the butt cap was tightened to adjust for the leather drying out? Also I noticed the solder on the hilt was applied kind of messy and it has stained/patina black in some areas of the solder. Does anyone know what kind of solder Randall used back then? I feel like it is strange to see a messy solder job with black spots based on other Randall's I have seen. The solder extends about an 1/8" from the blade on the back and sides and in the front of the blade it extends 3/8" into the hilt. the solder border is not uniform either. The different sized washers, uneven spacers, and messy solder got me wondering if this could have been a kit knife. I cannot see any markings that would indicate a kit knife and everything else seems very legitimate.
It came with a Johnson rough back sheath and the original Norton bear brand sp13 stone. From what I have read it should be a late 60's to early 70's. The washer pattern is thick red, thin white, extra thick greenish, thin white, and thick red. The stamp has the O inset from the R in Randall and the F is aligned in between the middle and right vertical lines of the M in made. I am certainly not an expert on these knives and I have spent the last couple of weeks researching them. Sorry about the lack of pictures but this forum is not photo friendly.
Thanks
Thanks
