- Feb 15, 2014
We would like to share the details about this model here with you.
Specification:
Ceramic ball bearing system
3-D machined Titanium handle Blade Length:3.35"
Blade Thickness:0.157"
Overall Length:7.67"
Hardness:60-61HRC
Handle Material:6AL4V Titanium
Blade Material:Damateel-RWL34/Damasteel
Weight:3.53 oz
Locking:Frame Lock Blade finish:Handle rubbed satin/Stone wash/Satin finish/Black PVD coating/Damasteel
Handle finish:Bead blast/Blue/Bronze/Black PVD coating
Here are some photos of Starboy.
Reate Knives would like to talk a little bit about one important techniqueFreeze Edging Skill.
As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. Thats why some knives passing the hardness standard test but still easily get worn in actual use.
Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thank you very much for your time.
Reate Knives Team.
Specification:
Hardness:60-61HRC
Weight:3.53 oz
Reate Knives Team.
