- Sep 9, 2003
Since it is common place for the same basic questions to be asked every 5 to 7 days by folks new to the topics and this board (once again, no problem that is how we learn), I thought it was only fair that I get to bring up and repeat a topic that I feel is very important to discuss again for the benefit of those who may have not heard it before.
As I sit here (all darned day) working on my presentations for an upcoming class, listening to music and enjoying a Montecristo platinum and a good bourbon, I am taking a break as I contemplate a recent conversation dealing with elasticity in metals and thinking that it is worth chatting about again. So I decided to put my side of the conversation here has a refresher thread on a topic that is VERY important to the bladesmith in 2008
There are two modes of deformation, plastic and elastic. This takes us back to the discussion about planes of atoms slipping half way to the next space and then returning to their original position or slipping all the way to the next slot over. Halfway = flex, all the way to next slot = bend. Anything in the elastic category is governed by Young's modulus which is the same regardless of heat treatment at room temperature. A fully hardened blade will take exactly the same amount of force to deflect it as an identical blade that is fully annealed. The only way to change "stiffness" is to make it thinner or thicker. Of course as soon as the steel takes a set at all you have moved from elastic to plastic deformation and the modulus of elasticity no longer applies as you have reached the yield point. What heat treatment does is moves the yield point up and down within the elastic range (also called proportional range), a softer steel will bend much quicker in the elastic range but then has a much greater plastic range before failure, while a fully hardened piece of steel will resist any deformation and continue to flex much farther but will have much less of a plastic range before failing. It is much more difficult to bend the harder steel but the harder steel will not deform near as much before breaking. But both samples will take the exact same force to flex and return to true. Think of the laws of conservation of energy and matter, the universe will never give us a free lunch, all it will allow us to do is make trade offs.
Trying to measure our heat treatment by applying numbers or testing how much force it take to flex a blade does nothing but expose our lack of understanding of very basic principles that engineers and metallurgist use every day in designing beams in bridges buildings and any other structure that uses steel.
The simplest definition of strength in materials is resistance to deformation. That deformation could be plastic or brittle. However resistance to brittle failure is more accurately called toughness. But I like to use the term strength in one area- impact. I like to think of my blades as having impact strength as opposed to toughness, since toughness can be ever increasing with softness (a dead soft piece of 1018 will have superior toughness but I dont want a blade made from it ) while some steel can be heat treated to take greater impacts without going to softer extremes.
Common sense according to what our eyes see tells us that heat treat can affect stiffness, after all why do we have the term spring temper. However when you look closer, and I dont mean with microscopes or lab equipment but with the naked eye and pay close attention to how identical hard and soft steel pieces behave we see that what looks so simple and straight forward is not at all real. All of us have been lead to believe something by our culture that is not the case.
For more detailed information you can also see the following thread here:
http://www.bladeforums.com/forums/showthread.php?t=440355&highlight=curve+discussion
