This weekend I taught myself a valuable lesson on not using a cold axe on cold wood (didn't think it was that cold but axe was outside in gear box all night temps 40f guessing). While chopping up some small logs (4-6"dia) I noticed a piece missing from the heel end of the edge. I don't know if i hit a spike, knot or just bad luck. Is it worth grinding to repair or just leave it as it is? If I try to grind it what shape should I try to acheive? It worked fine the rest of the morning, just not sure if i should attempt repair. If I was to make it seem as if no damage was done, there will be a lot of grinding in my future. Would cutting the basic shape with a saw be easier and then forming with a file work better ? Any input would be great, thanks.
edited to add, it's a GB small forrest axe about 3-4 years old, gets a little use on camping trips half dozen times a year.
