- Dec 19, 2015
Add it to the list of my must haves! Axe, sdfk and b&t. I might have to start an onlyfans page but ill make it happen!
This will come across as a very dull (pun intended) comment. However, as I read your very interesting response I sensed that the thought process initiated at the hand. That is, from the experience of working with a knife in your hand to applying your knowledge of metallurgy to improve your experience with the knife, and not the other way around. This sounds lame to the max but I think it’s very important. I don’t know the first thing about steels but I’ve used knives for more years than I’d like to acknowledge and I’ve often found myself thinking about how the steel on my knife could better perform. And I believe the CPK approach is what makes these knives superior.
Nathan did his D2 work first, but it didn’t put him on the map. The Delta 3V HT protocol is a big part of what did, and that was essentially a 3 way collaboration at the time.
And there was a separate design collaboration with Lorien.
That isn’t a coincidence nor do I say it to take anything away from him. Things like the comp chopper came out of that success because it provided the resources required to pursue those interests.
A sad part of that success came at the hands of another makers failing, but this is life.
The question after D3V became what’s next? We found out regarding 4V. Well, I can tell you two things. Nathan gets bored of things, then he doesn’t want to make them anymore.
Second, pique his interest in a project and that is how you are likely to find he will work on it.
I believe, rather than pointing him backwards at a project that at this point was probably 10 years ago, and have him repeat it, why not take the desired application, research it yourself, find a specific need, and then see if Nathan can take what he’s learned for example the metallurgy and ergonomics, and combine it with hopefully a new material that he might find interesting.
That’s a good way, in my experience to have him visit a topic. I say this as someone who years ago worked very hard to get a run of a discontinued project, and felt some guilt about it afterward. I think Nathan actually liked me less for it.
