- Sep 4, 2004
My experience with S30V has been mixed, and that's putting it nicely. Many posts I see suggest it isn't just me, but having owned for any real length of time only five knives out of this steel, maybe I don't have enough to base any hard conclusions. Still, there's a pattern emerging.
I'm thinking S30V is very tricky to heat treat despite Crucible's claims. An unacceptable percentage of blades seem prone to chipping even with only light work. Of course this negates any edge holding advantage the steel is supposed to have if you want a very fine polished edge.
Even with the S30V blades I've owned and used that weren't flagrantly bad, what I consider obtuse edges are still necessary to prevent chipping. I haven't yet seen a S30V blade that you could knock the primary down to 10-12 degrees per side and run a 15 degree microbevel .... just not tough enough with that geometry, and you (well, I do) need the primary at least 15 degrees with 20 degree or better secondary to hold up at all well. But that kind of edge geometry hurts performance for a lot of things, and leaves me thinking what's the point in an expensive 'super' steel that you have to sharpen like a $10 hatchet?
What bugs me most..... somebody told me a year or so ago that Camillus was buying 50100-B for under $1/pound. I've got a couple Beckers and both hold a decent shaving sharp edge longer than any S30V blade I've used. VG-10 blades I've had hold as good or better an edge plus allow more acute edge angles I prefer.
Is it possible the S30V blades I've had that I thought were properly heat treated weren't, and all of them I've had were dogs? And if they are all dogs ..... well what does that say about S30V from a practical standpoint? Anybody had luck with more acute edge geometry, or found some real advantage to S30V ..... and if so, who are the makers or manufacturers doing a good job?
