the-accumulator
Platinum Member
- Jan 24, 2008
Several Cellidors arrived the last few days so thought I'd post them together.
First a vintage 91mm Fisherman, it has the old awl, square phillips with file, silver head tweezer as well as single spring scissors with clip pen blade and bail
Also a couple of 84mm small Tinkers, one with shield on the pile side, then the other is a bit older (no tools) with the old awl and clip pen blade as well as the slotted phillips or sometimes referred to as the tin can phillips? due to the slot partially down the center.
The can opener tip was damaged so I re-profiled it so the edge wasn't jagged
You can see the light through the slotted phillips
Then a 84mm cellidor Electrician. I like this one, nice and thin and basic tools, Spear, Sheepfoot and Phillips
Others arrived as well but was only able to post these right now
