So this is a point of terminology that I think many may disagree on. Over the years I have seen many different definitions presented from different dictionaries, encyclopedias, and sources other wise. Most dictionaries for instance might tell you that a scabbard is for a sword, dagger or an axe. And that a sheath is for a knife. But these same dictionaries won't make a clear distinction between a knife, large knife or a dagger.
Some would say based off the ambiguity of available definitions towards meaning (the word derivation being the only solid and known thing) that sheaths and scabbards are the same thing. That it is just down to a difference in word etymology. While both are longstanding in the English language scabbard is basically of french origin, and sheath of German origin. Sheath having entered the English language earlier. Others will give all sorts of qualifications for distinguishing a difference between the two. None of which (including my own) are authoritative or incredibly well evidenced from what I have seen. Personally I think that while there may not necessarily be a a significant difference between the meaning of the words. The way I personally have come to define both and delineate between them I find to be very useful for sake of clarity. And is as follows:
Scabbard.
A Scabbard is a rigid container for a bladed and edged implement. It is often, though not necessarily, of multi-layer construction. An inner and outer layer. The outer layer protecting the implement from outside influences and the inner layer protecting the implement form the outer layer (both as an insulator and as providing a difference in hardness from the outer material). The inner layer also usually has a dual purpose of creating gas/fluid tight environment for the implement. Securing of the implement in the scabbard is usually based on gravity fed containment (relying primarily on an ideal range of orientation to keep the implement in the container). A Scabbard may have a secondary securing piece intended to prevent unintentional removal when the whole is outside the range of ideal orientation.
Sheath.
A sheath is flexible or semi-rigid container for a bladed and edged implement. It is often, though not necessarily, of single layer construction. Wherein the inside of the main body material is of a different treatment then the outside. Sheaths often allow gas/fluid to pass through them to some degree. Either because of the nature of the material used, by design of the container, or both. Securing of the implement in the Sheath is usually based on a friction fit (either points of close contact with the implement or full contact). A Sheath might not (but often does) have a secondary securing piece intended to prevent unintentional removal when the whole is outside the range of ideal orientation.
The differences.
Sheaths are often lighter and less bulky then scabbards of the same length and width. As well as easier to construct, maintain, and repair than scabbards are. However the added weight, complexity, and bulk of a scabbard comes with a greater level of long term protection for the implement. This tends to make sheaths better for tool application. Wherein a craftsman/laborer might be frequently maintaining the implement anyway as part of it's regular use. And can often have full control over the environmental conditions the whole will be exposed to. Therefore the sheath only needs to offer interim protection between maintenance and use.
However scabbards are typically better for weapon application. Wherein a soldier/warrior might need to transport the implement over long distances. With the whole's environmental treatment largely outside of their control or unpredictable. And where most of the time the implement will not be in use. More long term storage and less time for maintenance with only occasional usage, necessitates a higher preservation of initial condition of the implement. Given the nature of modern warfare and the greatly reduced likely hood that the common man is going to be involved in civil combat with a bladed and edged weapon.
Scabbards for practical purposes have largely fallen wayside. And are mostly seen when newly produced as part of reproduction or novel weapon offerings. Whereas sheaths have maintained their popular use. Not only through the constant and non-declining need to protect tools. But through lower manufacturing costs.
So that is my treatment of it. But I am curious to see what others think about the subject. Do you think that there is a difference between a sheath and a scabbard; Or do you think that they are interchangeable words for what is essentially the same thing? If you do think there is a difference; Would you agree with what I have put forward here as the definitions and differences? Do you partially agree but would change some things about it for your own espousal? Or do you have entirely different set of criterion/qualifications? Or if you don't have a fully formed opinion on it really...Has the interchangeable usage sometimes confused you? Do you ever find yourself using one word, then thinking about it and wondering if it would have been better to use the other?
Scabbard.
Sheath.
The differences.
