Should you just get the basic model and add different rods later? What is the basic model and what does it come with, and where is the best place to order one?
Thanks, I might get a Sharpmaker next instead of a new knife. Moneys tight so I go month to month.
you really can't get the lansky clamp to hold the knife straight. and the sharp maker dulls tips if you're not careful, so keep an eye out. I had to be done with knives for a while until I can afford a sharpener that's easier to use for someone as dumb as I am, for those two reasons. lol
Yeah your point is well taken concerning the "rounding or damaging of knife points" if you're not careful. What I do to remedy that is to pull the blade downward and back to myself and then I stop right when the tip is still on the stone. By doing it that way I'm careful not to come off of the stone. By keeping the very tip on the stone and not letting if slide off will indeed keep it from being rounded off or damaged.
Bottom Line: you want to push you your knife blades slowly downware and carefully watch to see so you can stop while your tip is still about the middle of the flat part of the stone. When working the corners of the stones I don't pull the blade near the tip >> I stop about 1/2 to 3/4 of an inch before the tip reaches the corner.
Like I've said before it really pays to give close attention to the video that comes the unit when you buy it new.
Thanks, I'll keep an eye on the tip. Just how do you keep the tip sharp if you don't keep the edge on the stone?
You really should. I think the SM should always come early in the collection. It will ended up getting more use than any other Spyderco purchase and it really adds a whole new dimension to this little hobby.
