Originally posted by firkin
I like the idea of the sheath made from honing leather so a strop is easily available.
HandAmerican says that their leather has been specially compressed, and also offer a compressed/treated version.
Would this make these leathers unsuitable for molded sheath construction? Would the desirable properties they have imparted to the leather be lost in the molding process?
Maybe a belt made of the stuff is the way to go?
1st question..... Yes.
2nd question....... If that's what you want.
Firkin any decent heavy leather, vegetable tanned, so suitable for tooling and/or taking the grit from a polishing compound, would be suitable for making a strop.
There's no need of any compresssing or such.
The problem with a scabbard of belt made into a strop is that the cutting or polishing compound you put on it is subject to getting all over anything next to it as well as picking up undesirable grit from the terrain.
Just wear a decent 10 to 12 ounce leather belt without any compound and simply strop on it. It won't do the job a real strop will, but will be suitable for removing a burr edge on any knife.
Lots of old timers used to use the smooth underside of their leather soles on their shoes next to the heel where the leather was basically clean to strop thier knives.
If you happened to be wearing boots so much the better because then the surface was rounded.
As has already been mentioned, "Dragging a freshly honed edge over a piece of hard wood will remove the final burr edge on a knife." there's no sense in trying to reinvent the wheel. Use what's available in nature.
