Hey all, just some quick questions about sharpening I was hoping to get some of your tips or techniques. I have some kind of problem sharpening knives. I practiced all the time with stone, trying everything but just haven't figured out how to sharpen multi-bevel knives. That is why I loved my lueko so much, just a quick strop and it was good to go.
Recently I have been harder on the edge and it needs a real sharpening. I have a couple mousepads with some 800/1000/1200 wet/dry sandpaper from an autostore. It seems like i can get the edge close to the handle sharp, but the tip I have some trouble with. I think this is due to the grind angle of my bushcrafter, a little wider by the handle and tapering out to the tip it seems. Should I be lifting the spine up to create MORE angle between the pad and the spine? OR should I be keeping the angle constant? When I strop I found that I could life the blade up to get all the edge sharpened, BUT I have never been able to really get it to push cut fine curls in paper. It will cut it very smooth with a little bit of drawing/slicing but never totally razor sharp. I am not really needing a razor sharp edge, just trying to learn how to get different edges. I don't have a natural instinct on this.....clearly. I am trying to work to get a razor sharp, hair cutting edge and see how that holds up, and then try a tougher edge to compare.
When I strop I find the angle by pushing the sharp edge into the leather until it catches, then using that angle and drawing back. Is this the same angle I should be using when I use the paper?
Any other tips?
Any other tips?
