Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Well hell, all of the knives I make can do that! That usuba in the two videos can push cut a green onion just from the weight of the knife, and it's a very light blade.sharp is when you can push cut the tomato
Diamond mostly. I was able to wear them down a bit with carborundum and Akansas stones, polish them more like it, LOL. It took many hours to put an edge on it, and I wore out several diamond stones and an angle grinder grinding disc. Belt sander was no use. I used the angle grinder to flatten the teeth, and by the time they were flat the disc was worn down smooth and wouldn't cut very well and although I tried for a while to use it to put a bevel on the edge, I finally gave up because I wasn't getting anywhere. A 200 grit diamond stone cut it pretty well though.Did you sharpen the tungsten carbide in your knife with CBN and/or diamond or with other abrasives ?
a very good sharpness test is cutting tomato (skin) at 100% perpendicular angle and without pressure whatsoever.
slicing through a tomato at an angle other than 90degree AND with slicing motion AND with some pressure isn't too challenging.
try 90.0degree, no pressure, only ⅛th of an inch slicing motion! if your edge doesn't cut the tomato skin under this condition triplet, go back to your stones and try apexing again!
this test result is even more revealing and impressive than the flashlight\apex\reflection trick. it gives the final PASS.
I like the grape drop. That is just KOOL!I learned a couple of new sharpness tests (new to me anyhow)
The Grape Drop Test - drop a grape from 20" onto the edge.
Get a Catra sharpness tester
