- May 17, 2018
I've seen posts about "What do you do when you need a sheath." Here is what I did.
I needed a sheath for a villager knife. I used a heat gun (in a ventilated area) to heat up a 2" piece of PVC. After shaping it to the blade I ground off the excess and epoxied it together. Drilled some holes for a cord and sprayed it with textured paint. Pretty easy and cheap.
I got the idea from You Tube.
