1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Shirogorov F95 pivot issue/ Lock Stick
Discussion in 'Maintenance, Tinkering & Embellishment' started by Skipper623, Jan 12, 2018.
  1. Skipper623
    Skipper623 Gold Member Gold Member
    28
    Feb 9, 2017
    Hi all, I'm sure this has been beat to death but I've been trying for days to get the pivot off my shiro but I can't do anything without the pivot spinning. I've tried using a blow drier, putting it in the oven on low heat as well as using boiling water and no matter what I do I can't seem to get the pivot off. Any other thoughts?
  2. miso2
    miso2 Gold Member Gold Member
    Nov 19, 2014
    For free spinning pivot, you have to somehow secure the female pivot.
    Assuming that the thread locker is fully broken, you can try to secure it by pressing rubber onto the pivot screw head while loosening the male pivot screw.
    Alternatively, you could glue the female pivot by putting superglue or permanent thread locker.
    But unless you are desperate, do not try this and disassemble it.
    gunfixrjoe and Lapedog like this.
  3. Skipper623
    28
    Feb 9, 2017
    That loctite trick seems like my only option at this point, my only worry is how difficult it will be to get the female side back out?
  4. miso2
    Nov 19, 2014
    It won't be difficult if you apply heat to it.
    Just make sure you don't put too much loctite and contaminate the bearings.
  5. Skipper623
    28
    Feb 9, 2017
    Ok thanks for the help, will see how it goes today!
  6. dustinarai
    dustinarai Gold Member Gold Member
    172
    Feb 17, 2002
    Loctite Blue 242 breaks down around 300F, you need to leave the hair dryer on the highest for up to 10min depending on the wattage. To secure the flat female side I use a rubber glove. If it's not breaking loose its not getting hot enough.
  7. Skipper623
    28
    Feb 9, 2017
    Good to know I wasn't aware of the exact temperature, it could just be I haven't been going hot enough.
  8. miso2
    Nov 19, 2014
  9. razor-edge-knives
    razor-edge-knives KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Apr 3, 2011
    I can remove that for you if needed, and I have replacement screws if you need them as well
    marcus52AR and Skipper623 like this.
  10. Skipper623
    28
    Feb 9, 2017
    Cool if I still can't get it out I'll reach out to you for sure, where are you located?
  11. Skipper623
    28
    Feb 9, 2017
    So Nick Shabazz technique worked! Although I didn't have to use red loctite, just a dab of blue loctite and let it sit for a few hours and boom came out like a charm!
    lex2006 likes this.
  12. Skipper623
    28
    Feb 9, 2017
    Now if only I can get that centering dialed back in... it's close but not perfect.
  13. Skipper623
    28
    Feb 9, 2017
    So before I took my knife apart my knife had zero lock stick, now that I have it back together, everything seems solid except now I have really bad lock stick, it's not impossible to open, but it takes noticeably more force and makes a loud click when disengaging, I've tried Sharpie on the tang but that doesn't seem to be helping, any thoughts?
  14. marcus52AR
    marcus52AR Gold Member Gold Member
    Apr 22, 2014
    Maybe try tweaking the pivot a bit tighter. If the pivot is still free dropping, tighten it up until it's just shy of free. Try a few flips and then back off a tad on the pivot tightness.
    I've had to re lock-tite my pivot a couple of times. There's a sweet spot where when it locks up the Ti makes a more solid noise and you can feel it reverberate in the handle.
    Mine's a F-95 nudist full TI.
    Possibly could be too tight as well..
Share This Page
