- Nov 14, 2013
Do you find you prefer one over the other? why? Im guessing the satin blade will flick easier because of less friction, which I would appreciate.
Most of us prefer satin blades; won't show scratches and scuffs as readily. And yes esp. around the pivot/tang area the blade could open smoother. With most stainless steels coating is mostly for looks, but for high-carbon steels like 1095, M2, and M4 protection it's important to prevent rust and corrosion, so coating is important. The key in any option is to keep both knife and blade clean.
I prefer DLC blades. I don't care much for the cerakote. For the record, my M4 Griptilian is as smooth as smooth can be. The pivot may need cleaned on yours because mine doesn't feel the least bit gritty.I usually go satin. Hides wear and is smoother opening; I own a cerakote M4 Mini Grip and I absolutely hate the action on it. It's gritty and slow due to the cerakote, but I live with it because M4 is a beast at cutting performance. Still, I don't plan on ever getting another cerakoted blade, regardless of steel.
cerakote will be just as smooth opening. not gritty.
