I think handles might stay tighter if you could overdry or otherwise shrink the wood prior to installation. It should stay tighter longer. I think I will try this next time.
For you, maybe. An hour isn't going to do much except overheat the surface. Wood is a pretty good insulator. By the way, the common mistake of placing a piece of wood in an oven on a lower rack during the initial heat cycle can subject it to broil-type intense heat from the bottom element until the elsewhere-located temp sensor registers an overall internal temp. Oftentimes these units aren't very sensitive and take awhile to trip. Do not stick a piece of wood in an oven until it's already warmed up and to be absolutely sure take the wood out in between heating cycles. A 200 F pre-warmed oven will remain plenty warm for drying purposes for another 2-3 hours after it's been turned off.I put a handle in the oven once. It was a factory made kiln dried handle. I had it in for an hour at the lowest setting, around 170 degrees. I was warming it to then hit it with beeswax. It split. It's a bad idea.
Gas oven, pre-heated, top rack. It split. Your mileage may vary. I won't do it again.For you, maybe. An hour isn't going to do much except overheat the surface. Wood is a pretty good insulator. By the way, the common mistake of placing a piece of wood in an oven on a lower rack during the initial heat cycle can subject it to broil-type intense heat from the bottom element until the elsewhere-located temp sensor registers an overall internal temp. Oftentimes these units aren't very sensitive and take awhile to trip. Do not stick a piece of wood in an oven until it's already warmed up and to be absolutely sure take the wood out in between heating cycles. A 200 F pre-warmed oven will remain plenty warm for drying purposes for another 2-3 hours after it's been turned off.
Yep. If I order some handles from House for instance, they are air dried. Their climate is not my climate and if they don't get further drying it will be a loose head when the haft does reach equilibrium with my climate. All kinds of ways to accomplish taking the haft down a percentage or two lower than equilibrium to your climate. Lots go into that, like the time of the year you hang your axe and how you store your hafts ect. Its a good practice to have your hafts drier at the time of hanging then they will be when they reach equilibrium during your driest season. Should be a best practice type of thing...I think handles might stay tighter if you could overdry or otherwise shrink the wood prior to installation. It should stay tighter longer. I think I will try this next time.
Convenient memory jb. And sound advice derived from a wealth of experience. Sort of like saying "I put a wood handle on an axe once and it broke. I'll never use wood again".Gas oven, pre-heated, top rack. It split. Your mileage may vary. I won't do it again.
It sounds suspiciously like you are questioning my honesty, in an underhanded way. Again.Convenient memory jb. And sound advice derived from a wealth of experience. Sort of like saying "I put a wood handle on an axe once and it broke. I'll never use wood again".
First line of any weak defense is to evade the issue by invoking slight to 'personal integrity'. So this now becomes my fault and not yours? I wasn't born yesterday jb.It sounds suspiciously like you are questioning my honesty, in an underhanded way. Again.
I don't even know why, I'm just offering my opinion and experiences, just like you. But I don't care enough to go through this BS. I'll need to figure out how to block your posts, won't be an issue again.
Less aggressive than ovening, but how would you control the moisture loss? It's when the moisture loss at the end grain out paces loss along the grain that checks are likely to occur. In order to equalize moisture transfer, and prevent strange and unwanted things happening to your handle, the entire handle would need to be buried plus the end grains sealed. On top of that the capacity of the rice to take on the moisture from the wood would have to be gauged to the present moisture content of the wood and the desired moisture content.I like the concept.. what about sticking the top of the handle into a bucket of rice or similar to draw moisture out of that end? Thoughts?
