- Feb 11, 2014
Hey folks, the title says it all. I recently got an m7 in satin and I've read that the steel rusts easily. Opinions?
It's a D-2 clone but has less Chrome (7.8%). Most D-2's are around 11% Chrome
It's not right. D2 is a ledeburitic steel. Sleipner is a 8% tool steel family. Finer carbide...
The Knife Steel Chart calls Sleipner a Modification of the classic AISI D2 tool steel having improved toughness compared to D2. If you need a fine grain, which I like, D2 is available in a CPM version.
I would be interested in hearing your opinion, as to the benefits of Sleipner over D2. I have an SR2A in Sleipner, & in practice I haven't noticed a difference.
I'm sure Lionsteel has reasons for choosing those two steels.
I choosed this steel because it's tougher D2, no problem chipping on edge, and have also a very good edge retention.
How about corrosion resistance? it seems like its on par with A2
It have better corrosion resistance than A2.
It's very difficult to si on it red rust (active), It can have black rust (passive).
The water infiltrates any knife that has a detachable handle. You can use Touf Cloath on the tang in the handle or use nothing. If you use the knife you'll see marked. A little passive oxide in the handle does not change things.
Some weeks.
Sun, rain, humidity...
