- Sep 19, 2001
these are from two 17 x 1.25 x .062 Lenox mo-speed blades, 10 teeth per inch.
I have to slim down the handles on the top two, and I'm trying to see if I can leave the saw teeth on the spine of the top one. The middle one is just a mess, but will hopefully turn into a mild drop point. Next one will have a curved spine, so I think I'm gonna have to remove the straight section on the edge to keep it looking right. Last one will be a wharnie, had to blunt the tip cause it kept overheating.
If I can finish profiling, and not blow the primary grind, I'll epoxy some wood scales on.
Better tools would help, I'm using a little 3" bench grinder with flexshaft attachment (that loses a lot of grease), 1 x 30 belt sander, and a 4" angle grinder with grinding disc and cutoff wheel.
