I use this small part vise all the time in the shop when I am working on guards. I clamp this small parts vise in my larger bench vise and it is very secure and easy to use with the pool cue handle. I used to use a small machinists parallel clamps for this job, but ever since I made this vise it is the only thing I use. I made a couple more recently and took a bunch of pictures along the way in case anyone wants to make one. A detailed drawing is attached at the end.
Starting with a 9” long piece of 1” round steel
Cut the bar down the middle and cut out a 6” section. Alternatively, if you do not want to use a 1” round bar, I would suggest using 5/8” thick by ¾” wide flat stock. The round bar is nice, as you can rotate it in the vise in any direction, but flat stock would be totally fine as well.
Drilling the ¼” hole
Using the drilled hole, to mark the spot for the ¼”-20 tapped hole
Enlarging the ¼” hole to provide a recess for the bolt head
