There is a GEC retail seller that regrinds the GEC #71 into a clip blade. It's sold under the Due South Brand. Just Google "Due South 71".Has anyone ever or does anyone make a sodbuster with a clip blade? Or would this be considered a different pattern all together once you change the blade design?
Case sodbusters have clip blades do they not ?Has anyone ever or does anyone make a sodbuster with a clip blade? Or would this be considered a different pattern all together once you change the blade design?
It may be pretty subtle but, there's a very slight clip to my sodbuster Jr.They do not. Simple straight back, same profile as most puukkos.
I suppose you're right.It's definitely not a clip. It's more of a drop point. Some knife companies call the Sodbuster style blade a Skinner blade.
I can't link it directly because the mods consider it spam, but the second most recent article on my blog "knife thoughts" talks about blade shapes. You should find it if you search "knife thoughts guide to blade shapes"
Hey GT, I would call each of those drop points.I would probably better appreciate some of the subtle differences described in this thread if there were more photos. Here's a pic (actually a scan) of a Case Sodbuster Jr and a JJ Martinez navaja de campaña that I usually call a Spanish sodbuster. I've naively thought for years that they had almost identical blades, but after the discussion here "raised my consciousness", there are obvious differences. The Spanish knife obviously has a drop point blade (right? or is it a spear?), while the Case has a skinner blade with much more "upsweep" at the tip of the cutting edge.
- GT
The Case Sodbuster is their version of a knife that has been around for a long time. The Germans have called them Hippekniep, Taschenschlachtmesser or Notschlachtmesser for over 100 years. During that time, they had many different blade shapes including clip points. Rainer Morsbach currently makes a knife they call a Notschlachtmesser with a clip point.Has anyone ever or does anyone make a sodbuster with a clip blade?
I guess what throws me off is that the lines on the case sodbuster are straight, the transition is so subtle that there's no defined angle but there's no destinct curvature that I can see on mine.
- GT
I disagree. Lay the spine on a flat surface. You will see the curvature. All of my sodbusters have a more or less subtly dropped point. The Cases, and my Loewen Hippekniep have a fair amount of belly. The Maserin Plows are more pointy, with less belly. The Kutmaster Hog Knife, a Fleet Farm lockback, is the pointiest, with the most obvious drop.
Gotta go right now. If this point is still germane when I get back, I will illustrate with some photos.
You must have (like me) grown up in the sixties.... carryin around a hippie-knife..... and here I thought hippies were peaceful, flower-loving people.![]()
I bought that knife in Amsterdam in 1970. I survived the sixties pretty much without carrying a knife.
