bubbaskyjacker
- Feb 24, 2008
Like new HHW LFT01, never used just looked at and shown off. This think is built like a tank!! Super ergonomic with 3 holds depending on use.
Perfect for you go bag , or car emergency kit. It’s also short enough to fit into a backpack just Incase your urban environment goes in the toilet. Anyway if you want a beastly tomahawk that can take on anything, this is the one. Even the company says it was build for smashing through concrete !!!!
See pics for accurate condition, there are 3 tiny spots where the coating has come off, it came to me that way. This should not be a show piece , it should be destroying things anyway.The best tomahawk sheath there is.
sold.... F&F- money order, check. Add 3% for G&S. Not really interested in trades,
Now a word from our sponsor
The LFT is constructed from D2 Tool Steel, has a robust Teflon coating and G-10 contoured handle. Overall Length: 12.5", Axe Edge Width: 2.95", Spike Width: 1.05", Tool Material: D2 Tool Steel, 50 - 55 HRC, Tool Finish: Tan Teflon, Tool Thickness: .31", Handle Material desert BrownG-10, Weight: 1 Lb. 15.6 Oz., Carry System: Coyote Brown Kydex Speed Scabbard w/MOLLE Lock
LFT01 tactical tomahawk is ready for the extreme end of Hardcore use as an impact/MOE/CQB tool. At two-thirds the size of our BFT01G hawks, the LFT01 is designed for those operators who require a more compact tool capable of devastating performance.
The primary cutting head is razor sharp and the spike at the business end of things has a modified Tanto point specifically designed for maximum penetration. Its pommel is well suited for hammering and incorporates a large lanyard hole for the attachment of a carabineer or rope lanyard. The LFT01's ergonomic G10 handle has been designed for multiple handhold positions to suit operators, during single or double-handed use.
Some of the tasks we expect you'll use our LFT01 for include the following: chopping, hammering, digging, cutting, as a climbing aid, defeating locks, smashing windows & windscreens and raking out their frames, puncturing steel radial tyres, smashing steel clad doors and breaking through walls including those made of brick.
The LFT01 is constructed from D2 tool steel, has a robust black Teflon coating and G10 handle. Our G10 grip scales are secured with Torx screw, all steel fittings.
