- Oct 18, 2001
How does one solder a guard onto a knife without ruining the heat treat? If you solder it on before the heat treat, wouldn't the heat treat loosen the solder joint? If you solder it on after the heat treat, wouldn't that ruin the temper?
I can't figure out how to go about this, other than combining the heat treat with soldering in one heat, but that seems wrong...
