Something that could cut a chain or a steel lock.
I'm confused...I thought the OP wanted to know what would be small and portable to cut through a lock or chain and yet be able to carry in a BOB. This implies they'll be walking and don't want to carry the weight in a pack. So if you're walking (on foot) then why do you need to cut a lock (unless it is to a building) when you can climb over the fence or walk around the gate?
If it is for a vehicle then the device doesn't need to be limited to a BOB but rather something you can carry in your vehicle.
If it is for your vehicle then size/weight isn't as big of a consideration. Also if it is for a building for survival then there is always a window that can be taken out, or a door can be breached, or siding can be removed to manage entrance.
So if the tool/device is for the vehicle and it is TRUELY AN EMERGENCY the question must be posed as: "What is the MOST EFFECTIVE tool to bypass locks/gates/chains/doors that:
1. Expends the least amount of time/energy (get in quickly)
2. Requires the least amount of dependency on technology that can fail (dead battery, out of fuel, circuit board failure)
3. Gives one the most flexibility and multiple tasks (so it can be used for other tasks and not just one)
4. Can be easily and safely carried in my vehicle
5. And easiest/least expensive for you to later repair/replace the lock/gate/chain/door?
If the device is for "on foot" then it goes back to my original statement: Why do you need to cut a lock when you can walk over, under or around? If it is for a building then say so...and then we can discuss options/ideas for ingressing into buildings (which is illegal unless it is an absolute emergency situation and there are other no other options for survival/life support).
Generally it is bad policy to carry devices on your person that can be used for potential crimes without some rationale reason. Granted a firearm for example can be used for a crime, but it is generally widely accepted to carry a firearm for personal defense against two and four legged predators or to feed oneself (Hunting). But most folks do not carry a lock picking set or crow bar when backpacking, hiking, or hunting. If you're backpacking in an area where there are frequent building break-ins and you're walking around with a lock pick set or crow bar in your back pack - "Lucy, you have some 'splain'n to do..." It isn't illegal but why add additional culpability when you really don't need it. Generally back packers and wilderness travelers don't carry a lock pick, cutting torch or crow bar in their back pack unless intended for nefarious intentions.
We do see these devices in vehicles frequently because of various reasons so that is less suspicious. But in a pack? Well, something to seriously think about at least...
If we're learning wilderness survival then we should really learn multiple ways to make natural shelters or use the technology (tents/tarps) we buy to build shelters with, and how to start fires with one hand/arm under the worst of conditions with all natural materials and without aids such as petro soaked cotton balls, rather than rely on destroying private property. Yes, breaching a door is always an option - but it should be a last ditch resort when all other options have failed. If we can do as Les Stroud does, practice real world skills under realistic (but under supervision) conditions then we should be able to survive some really serious situations while waiting for rescue without having to resort to private property damage. Generally many of us are over-relying on technology and hardware (tools, gear, stuff) to solve our survival problems when programming proper software (proper supervised training) is going to build our confidence and competence to survive any or most situations with the least amount of gear. I'm finding the more I train with people (professionals generally) who really know what they're doing and can transfer their skills/knowledge successfully to me the less I need to rely on gear and extreme measures to survive. But what the heck do I know?
Again I cast my vote for a set (or two) of lock picks and a folding saw that takes sawzall blades. The lock picks will let you quickly get into all but the highest security locks, while the folding saw will let you handle metal bars, wooden beams, drywall, or just about anything else. Blades are cheap, and come in a wide array of styles.
In addition to the traditional lock picks I also recommend some of these jiggler keys:
They're cheap and incredibly fast/easy to use. They only work on low-security locks like standard MasterLocks and the like though, so that's where the real picks come into play. :)
Oh--and just make sure picks are ok for you to have where you live. They're illegal in some areas.
If you want a lightweight, cheap saw for cutting metal- junior hacksaw. Just make sure the blades are good quality, eg. Eclipse, and carry spares.
It's not illegal to own and carry lockpicks in the UK. However, as has been mentioned, you may have some explaining to do if you are caught with them and have no good reason...
Stanley makes a compact hacksaw that uses full size blades, but it's a fraction of the size. If you head down to HD you'll find it in the tool area with the other saws and it's under $12. I've used them in construction many times where a full size won't fit and it works great and is tough as nails.
insert jerky.
:confused: Hmmm. Sorry if you thought I was poking fun with my suggestion regarding explosives. Sometimes I do try to be a bit funny on this forum, but this time I was making a genuine suggestion. It would be unlike me to want to mock or hurt anyone.
I have used explosives to move rock in relation to road and wharf construction and I am in awe of their power. Although I haven't tried it myself, I am aware that simple detonating cord can be used to cut through steel. It is light and does not take up much space. It needs to be 'set off' with a detonator, and you have to handle detonators carefully.
Sure it makes a big noise, and sure... you could get yourself into trouble being in possession of it unless you are qualified to own it. But cutting through somebody else's chains, locks and window bars are also likely to land you in trouble - if you are caught - irrespective of whether you use a gas torch or a nail file.
One thing I didn't mention in my earlier two posts is that I often have 'just in case' a bimetal hacksaw blade with high speed steel teeth. It is small and light, and will cut through a wide variety of metal. A rag can be wrapped around one end to create a makeshift handle. Sometimes it is better to 'drag' the teeth toward you rather than push the teeth through the job. If you push the blade it can buckle, crack or break. I don't know if they are universally available, but 'Eclipse' blades have served me well over the years in my work as a fitter and turner. But any (expensive) bimetal blade with high speed steel teeth should be of use. I'd choose a blade with fine or medium teeth - maybe 32 teeth per inch.
From my experience in opening padlocks, Raivaillac's suggestion of using a tapered pick-axe is a good one.
Best wishes.... Coote.
