- Apr 12, 2001
Hey forumites.
I saw that some of you changed your springs on various REKAT models to a lighter compression to keep the rolling lock from sticking open and toprovide a smoother opening. Did you do this by trimming it down by about 20%, or did some of you get a different spring?
I'm asking because my new Carnivore is a bit gritty and sticks open every 4th or 5th opening, meaning that I have to use a lot of force to push the release back. I took the knife apart and completely lubed it. I think that loosening the screws that go into the spacers helped too. Anyway, after all that lube, and I did the swing arm for the lock, the spring, the pivot, everything with Tuf Glide, and it still sticks open.
If I trim the spring, exactly how many coils should I take off? I'm hesitant to do this because I think the sticking will go away and I think the opening will smooth out after some cycling. Then I'll be left with a weak, unreliable spring. I'm thinking that REKAT made the compression of the spring a certain way with considerations of use and that modifying it will make it too weak once it has some wear on it and been compressed for a while.
Anyway, what do you think about trimming the spring and how much do I take off if it is a recommended action? I don't understand what people are talking about when they say they trimmed 20%, so maybe if you tell me about how many coils to remove my little brain will process the info better.
Also, mine is glued in. I should be able to trim it while it remains glued in, but if by some chance it comes off, or I need to pull it off, what kind of glue should I use to re-glue it?
Thanks guys!
BTW, I love my Carnivore. It is my EDC now, but damn my thumb is sore from trying to close it!
Jared Karr
Thanks guys!
Jared Karr
