Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I can sharpen my Gerber Paraframe (it was the dullest knife I've ever bought) to shaving sharp, my problem is the blade just looks like crap when I'm done. It feels like I get the left side good but the right side not so good, but then I look at both and it's the exact opposite. One side will look uneven and have different highlights all over.
That, and I seem to miss parts of the blade, so only sections will be shaving sharp. Usually top/middle part isn't as sharp as the lower middle and lower section. This is why I have yet to sharpen my Leek, because I'm afraid I'll make it worse. I keep testing ony my Gerber until I hopefully get things going well.
Anyone have a link to the rods I should get to reprofile edges on knives that aren't 20 degrees? I know I COULD do it with the mediums that come with the sharpmaker, but that'll take a while.
I did a bit of looking, and are the rods people are talking about to put a new bevel on a knife the $40 rods? That's a bit expensive. If that's how much the rods cost, I'll just do it on the medium ones and spend an extra hour doing it.
On a steel like S30V, you won't spend an hour. Think more in terms of days, possibly weeks unless you want to make a full-time effort of it.
My first attempt to reprofile an S30V Leek (from the 20-ish per side factory grind to 15 per side) on the medium stones... well I never finished. Put the knife aside and finished when newgraham had the diamond stones back in stock.
If you want to reprofile *and* save money, buy some (300 grit should be about right) sandpaper, wrap it around your stones and use that.
I think the best response is to have you understand that the Sharpmaker is a different animal for different purposes. The V sharpeners are quick and effective for edge maintenance. They aren't very good for grinding new bevels. That's where the Lansky will be a better choice. Perhaps the ideal thing is to own both. You can use the Lansky for bevel grinding and the Sharpmaker for quicker mainenance in between sharpenings. Makes sense to me. Yes, Spyderco measures the whole angle and Lansky measures the bevel angle. You have that right. Take care.
Folks, I just ordered a sharp maker. One issue I may have,however, is that I like to ensure that I raise a burr along the entire edge, and that's not possible if one alternates sides. Perhaps some see poor results, because they don't fully forma burr before starting the other side.Anyone else care to comment?
The sharpmakers biggest problem is that is doesn't remove metal very well.Folks, I just ordered a sharp maker. One issue I may have,however, is that I like to ensure that I raise a burr along the entire edge, and that's not possible if one alternates sides. Perhaps some see poor results, because they don't fully forma burr before starting the other side.Anyone else care to comment?
