You can also build "half" V-sharpener with basic tools. You can make it adjustable with a door hinge.
https://www.instructables.com/Knife-Sharpening-Jig-1/
I don't suppose you can return it? It's really the wrong tool if you need to rebevel knives, even with coarser stones as you cannot put pressure into it the way you need to.Not sure what to do now, having spent nearly £100 thinking I was buying something that'd be brilliant, now seems I've got to spend another £80 buying diamond rods to get it to do the job I thought it was going to do in the 1st place.
I don't understand.I currently have a double sided diamond stone for the heavier duty work and a wetstone for honing and can get my knives scary sharp but it just takes too long and want something more for everyday use that's effective and puts a "decent" edge on mainly kitchen knives but also pocket / EDC's as well.
I was just looking at it and as I can see it comes with 2 medium diamond rods and 2 ceramic rods. I don't know what did you expect but those sharpeners are not made for heavy reprofiling but to maintain the edge when it starts to get dull.I also have a Lansky Turn Box but I find if the knife's dull it's pretty useless
I have home made sharpener with similar clamps as KME (about 40 mm wide) and I can say this setup is not the best option for sharpening kitchen knives (longer blades).IMO there is more value from a setup like KME that can actually sharpen a dull knife
Love the SharpMaker, but it can be slow. I ordered the CBN rods for dull knives or reprofiling, and they work a treat. In fact you have to clean metal dust off the table after sharpening. You won't be sorry you ordered them.I ordered one any way and it was delivered today .... got to be honest it's no better than the Lansky Turn Box, have been working on a knife for ages and it's made no difference at all .... so frustrated.
Does anyone know what can I use to reprofile edges at a consistent angle that;s compatible and will then work with this for keeping them sharp.
I see nothing special in that video. What am I missing?The sharpmaker doesn’t have to be slow. Just change your technique… I’ve been using mine like this for years. And yes, it’ll take all the way dull to all the way sharp.
Uhhhh, that the technique is entirely different? It’s not alternating strokes only downward. You just hold it vertical and scrub one side at a time up and down. It’s MUCH faster and doesn’t round the tip because you don’t use the corners (only the flats), and don’t lift the blade off the stone.I see nothing special in that video. What am I missing?
I didn't realize that was unusual. I had a crock sticks setup with white and brown rods and even with vigorous scrubbing it was painfully slow on anything seriously dull. I'd have gone mad before a 20° to 15° reprofile was complete. I have a stand-alone Fine Sharpmaker rod and it is top quality but not any faster than other fine ceramics.Uhhhh, that the technique is entirely different? It’s not alternating strokes only downward. You just hold it vertical and scrub one side at a time up and down. It’s MUCH faster and doesn’t round the tip because you don’t use the corners (only the flats), and don’t lift the blade off the stone.
