If you would ask the general swedish population about knife steels you would not score many good answers. VG10 is also quite rare in Sweden, only Fällkniven basically and they export most knives anyway.
The people who I meet and who has a genuine interest in blade steels here are the custom makers and they use almost exclusively Sandvik 12C27 and Uddeholm AEB-L. They are quite similar and fulfill what they require, which is:
*Tough (Swedish knives are thinner than US ones)
*Easy to polish (custom guys loves this fact)
*Easy to sharpen (coarse grades like ATS-34, VG10 or 440C does not take a thin Scandi grind as easy)
*Good hardness range (58-60 HRC is most common for them)
About Moras. Many of my friends dont see the point in getting other knives than a few Moras. They are cheaper here in Sweden than the US and the performance is superb as a slicer imo. You get a stainless clipper here for 7$, and that includes 25% sales tax. I love more high-end knives but find it hard to not agree with their point of view. The good thing is that anyone can afford and try one.
Looks like Mora mostly uses High Carbon Steel, how does the non-laminated compare to the laminated?
As for their stainless blades, how does the 12C27mod (Eriksson) compare to 12C27 (Frost)?
I think it's well known that stainless steels have a higher corrosion resistance than non-stainless, but how drastic of a difference is it? Most of the corrosion tests are done by soaking the blade in salt water, but who ever actually lets their blade soak in salt water, or fresh water for that mater, for long periods of time besides divers or fishermen? So for northern forest use, where most of the water is fresh rivers, lakes, or rain, and the blade will not sit in the water for long periods of time but may still be wet consistently, does the difference in corrosion resistance actually make a significant difference?
What are people's thoughts on the wooden handles versus the rubber handles? I think I would like the feel of wood better, though the shape of the rubber handles may have a better grip.
Razorsharp, you mentioned Uddeholm AEB-L, I've never seen that mentioned before, more info? Also, you say that the coarse grade steels like VG10 don't take a "Scandi grind" as well, what do you mean by Scandi grind? Is that like sharpening on a grinding wheel as opposed to a flat stone? Also, I would think that a blade with a finer grain, which would make it more readily sharpened or ground down, would also make it more readily blunted and dull, thoughts?
Anyone, if you were to have one knife for the rest of your life, and it was to be your only tool besides your hands and teeth, and all modern technologies and conveniences were removed, which knife would you chose?
