that being said then a thinner knife should last longer for the same steel used.
I think the problem here is that you do not distinguish properly between edge thickness and edge angle. When we talk about edge thickness, we mean actually the thickness behind the edge. Nozh is not carrying out the tests to a stage where wear is so significant that the thickness behind the edge will affect the test. I might affect the cutting of the rope, as a thin edge might go easier through the rope (but then again, rope is very plyable, so the effect might be fairly small), but not the sharpness test afterwards, because at the very edge, both thick and thin edge look the same as the have the same edge angle and on thread cutting only the very edge comes in contact with the thread. (Which is btw. what Nozh has been saying all along ). No offense, but at the moment, I think, few people have as much experience, cutting rope than Nozh. If you go to his page and count out all his tests, it amounts to, what, close to 10,000 cuts through rope?
I agree with Larrin, I don't think there will be much destinction between thin and thick edge. It think with those steels that have an appreciable carbide fraction edge angle is really the key factor. I will dare to postulate, that these steels will perform very well for edge angles that are normally found on folding knives (10-12 deg per side minimum). I would expect that their performance will probably come crashing down at really low angles though. And not because of the thread testing afterwards, but because I suspect that you will experience carbide tearout during the rope cutting at very low angles.
