Leftytwogunz
- Apr 30, 2013
Seriously, face palm is right..
Virtual fixed blade perhaps? LT is that you?
A lot of those knives, Triad, PowerLock, Axis, etc, will snap their blades off before the lock fails.
Oh boy... hide yo CRKT's, hide yo spyderco's cuz dey suing errebody up in here!
But really, as much as I hate Cold Steel right now for the garbage they are pulling the Tri-Ad probably is the strongest. But is that really what you need? Because I would say that the compression lock is the safest and stronger than you could ever need it to be. With the compression lock you have your fingers out of the way when you operate it and there isn't a risk of a guillotine like detent sucking the blade back in when it is already 40% open and slicing your fingers.
Plus I would honestly say the compression lock is the most reliable as well because there isn't a spring to break or multiple small parts like there are on an axis lock, a tri-ad lock or other more complex locks. So strongest is Tri-Ad but that is also probably the worst measure for the overall performance and quality of a lock and the Tri-Ad really only excels at strength. In my opinion the compression lock hits all of the key points where it counts (strength, reliability, ease of use, safety etc.) and is a superior lock.
Also like others have said on almost any of these the blade is likely to snap before the lock. If you apply the pressure just right like in Cold Steels tests and you're perfectly putting the force in the right direction the lock may fail first but we've still seen the blades fail. Especially in cold steels case they seem to do a poor job with their heat treatments and their blades are particularly prone to failure..
I've never understood the obsession over the "strongest folding knife" thing. I've used a huge number of folding knives through out my adult life and never had a folder fail. Even the strongest locking mechanism on a folder, when pushed to extreme limits might not fail but the blade or the handle along the pivot will break.
Balisong. Once locked open, it will not close while using it. You will have to close it yourself.
I concur with the Tri-Ad lock and Bali-song.
However, if you are looking for the performance of a fixed blade, you should buy a fixed blade.
No locking mechanism can replace common sense.
Friction folders get my vote. IMO it's as close as a folder can get to a fixed blade.
