Sorry for the long post. I have a few questions regarding sharpening. I have a variety of knives with a variety of edges. My primary sharpening tool is a Spyderco sharpmaker. Owning a few knives with a convex edge I want to buy a strop.
Here are the questions:
1- Is a strop used only for convex edges only or do you use them on all edges:
2- Once an edge is sharpened on the Spyderco sharpmaker will the strop improve and sharpen the edge more? Or if you plan on using a strop should you not use the Sharpmaker at all?
3- If you do use the Sharpmaker than the strop could you recommend what grit to use on a strop after using the sharpmaker? I called Keith at Handamerican to buy a strop and he told me that I need to know what grit compound I need. Without knowing the grit of the white ceramic sticks of the sharpmaker I did not know what grit I would need for the next step for stropping.
Thanks in advance for any info,
Stuart
Stuart
