- May 2, 2004
Being a custom knife maker with a shop full of knife making machinery puts me in a position that most knife sharpeners do not find themselves in. It also makes my opinion a minority one.
Something I have found out over the years, no matter what technique is used to sharpen; not enough time is spent doing the "ground work" when sharpening a blade. That is all the work needed to get an edge to the point where a strop is needed. If the ground work is done then stropping should take but seconds. The burr should be ready to fall off the edge. This is true in making a knife. It should get easier as you go; if the ground work is done early then the final steps should be easy, or a least getting easier towards the end.
Just about any material, not peanut butter,
can be used to strop an edge, some work better than others. But the choice of strops should be dictated by the condition of the edge. If the edge is not deteriorated but little, a couple of passes on anything will restore the edge, being it coffee cup edge, or cardboard, or glossy paper; the leg of your blue jeans will work quite well. Once an edge has gotten to a certain point no strop material will work. I'm of the mind, never let an edge get to this point.
This is how the ERU sharpener came about. I wanted a tool that was more than a strop but less than a reprofile devise. The focus was a highly accurate adjustable devise that would function to restore an edge after it had gotten beyond the point where a piece of leather could be used to restore the edge. This tool needed to be small and compact so it could be easily carried in ones front pocket, to be pulled out and used when needed; when there was nothing about at all to be used to strop.
I am 71 this year and time is of the essence, as the saying goes. I've read of people who spend 8 or 10 hours putting an edge on a blade, taking the edge to a degree of shine one needs sun glasses just to use it. This makes me shudder, 8 hours spent doing a job that can be accomplished in 15 minutes is a huge waste of precious time. Its an old man thing.
You'll understand when your 71
Best regards, Fred
Best regards, Fred
