- Apr 12, 2009
Be careful with Barkeeper's Friend. It has oxalic acid, and an abrasive which could etch and scratch the finish. BKF is an awesome product, but I use it to clean my sharpening stones, not rust on my knives. You may try a mild metal polish such as Flitz. It can also change the finish if you rub alot.
Just read Obsessed, this is what happens when you read the op then post without reading the rest of the threads. OWE, I do believe there is an abrasive in the BKF, it works great on my porcelain sink.
Hey CJ.
I've been Googling on BKF, and have come across at least a couple of descriptions of it, that describe it as 'non-abrasive'. Here's the description I see in the Google listing of search results, from the BKF site:
"Non-abrasive cleansers for brass, copper, stainless steel, fiberglass, porcelain, tile, plastics, glass cooktops, formica, and marble."
And another description from Amazon:
"Bar Keepers Friend, 12 OZ Cleanser and Polish, Non Abrasive Powder, Removes Rust and Hard Water Stains, For Copper, Tile, Brass, Stainless Steel, Marble, Porcelain, Plastics and Glass Cooktops. "
Some descriptions I'm seeing are referring to it as a 'cleanser and polish'. If so, whatever abrasive might be in there is likely to be very fine, if it does indeed 'polish' surfaces.
I think if there's any abrasiveness to it at all, it's very mild. I used it a while back on some stainless flatware with a high chrome, polished finish (rubbed with either a Q-tip or fingertip), and it didn't leave any trace of scratch marks. I mixed it with some water, to make a paste, prior to rubbing it on. The BKF site does recommend pre-wetting the surfaces before applying the powder, so using it wet (diluted) might make a difference too. If the powder was rubbed dry onto a surface, might be an issue there. But that could also be a chemical issue. If used dry (undiluted), the chemical action would presumably be stronger.
If it was used in conjunction with a Scotch-Brite pad or some other 'scrubber', I could see this producing some scratches. I'm thinking whatever 'etching' is produced by BKF on some surfaces is more likely related to the chemical action. There is a warning on the BKF site that it shouldn't be used on lacquered surfaces. I could see a lacquered surface possibly being damaged by a mild abrasive, but on metals, I don't think abrasiveness is an issue.
Having said all the above, it does show the importance of reading all the warnings on the label and, when in doubt, test it on a small, inconspicuous area to be sure.
