Sort of.
A view from a systems engineering point of view...
Scientific materials testing only makes sense if one has done the pre-work necessary to produce narrowly constrained definition of a particular behavior of the material and (this is even harder) the pre-work necessary to know that this narrowly defined material behavior is directly correlated with some performance outcome that you want to achieve. This last bit is really hard part, as (from a systems engineering perspective) you need to account all of the ways the user is going to perform the task (the skier is a part of the ski/snow/skier system) and the conditions under which the task is going to perform (the snow is a part of the ski/snow/skier system).
With knife cutting discussion, we almost never have sufficient definitional rigor to adequately describe the type of material to be cut, the techniques used to make the cuts and the conditions under which the cuts are being made. The elimination of variable approach of materials science makes sense if and only if the narrowly defined testing criteria map directly on modality that we know will be seen in actual usage. Elimination of variables in actual usage is very hard.
Another way to say this that performance attributes like "toughness" and "edge retention" have different meanings in a materials engineering context than in a systems/performance engineering context. In the former, toughness can be equate with a test like, say the Charpy test, edge retention with the CARTA test, hardness with the Rockwell test and so on. But in actual usage, toughness needs to be understood in terms of the sorts of impacts the knife receives, the materials encountered and the sorts of deformations typically seen in that particular use case. Different use cases might generate different deformations or fractures and more to the point, one use case may be more closely modeled by the Charpy test than the other. The CARTA test establishes edge retention for a certain kind of cut in a certain kind of media and is more predictive for actual use cases in which the cutting type and cut medium are similar.
I believe Larren understands the distinction I'm making which is why he correctly has said that he tests steel, not knives. Knife testing is like car testing, bike testing, rifle testing, plane testing, and car testing. It's in the realm of systems engineering and the user and medium are all a part of that. Simple version... if you want to know what the best chopper steel (and knife design) is, look at the knives that consistently win chopping contests. That will tell you more than lab results and more correctly, will direct what you can and can't learn in standardized labs tests.
