Will P. said:
Furniture is either made of heavy woods or wood/glue composite.
Depends, around here white pine is commonly used on the higher end, this is really soft, you can score it with your fingernail. Most of the working class functional grade is lower as spruce is the common local wood, pressboard laminates are in the really cheap stuff.
Good point about the dynamic cuts, but edge chipping is much different than castastrophic failure due to fracturing or deformation - once again, swords should to shear through denser objects rather than chop/cut. That's part of what makes it a sword.
Not all swords function in the same manner, read the posts by Clements in rec.knives a few weeks back on various swords which chopped and even functioned as blunt objects as there was no edge to speak of, sword covers a broad scope of blades.
Many of the profiles described are horribly thick and blunt compared to what are found on wood working blades and you could take those swords and pound on desks all day long and do nothing, you could crack them into nails if you wanted with little effect.
Note the long graceful arc on a katana and the convex cross section is near identical to a traditional golok, which is also used in the same draw manner instead of a pure chop, even simple machetes will be used in the same manner as are khukuris.
Pressure is the wrong term. The crystal structure of the steel fratuces or deforms, but does not compress - pressure occurs in fluids, not crystals.
Not speaking of the internal media and a resulting corrosponding chance in density, but what is exerted upon it. There is a large pressure upon the edge of a knife if you chop into a branch vs the trunk of the tree, this higher pressure can easily be enough to surpass the critical yeild point and cause the steel to deform or crack depending on how fast it is applied and its magnitude. Note many of the critical properties of steels are in units of pressure as it is a force being applied over an area to normalize it for a standard.
If you hit the broad side of a 2x4 with a sword, you will get a strong resistance to the shearing forces and can damage the sword.
Only if it is made out of unhardened steel, or is a *really* thin sword. Why would you expect a forged piece of 3/16"-1/4" tool steel to be functionally far weaker than a 1/8" stamped machete you can buy for $10.
I'm not should how you consider a bone impact to be taking place in a short time period than contact with a 2x4
Bone is harder, Apatite which is the main mineral component of bone, is about 35 on the Rockwell 'C' scale, wood is much softer. I can take a decent large bowie and cut for example 2" deep into a 3" piece of pine, 6 square inches. If I chopped into this much bone the knife would not get anywhere near that level of penetration, as the distance traveled is much shorter so is the time of the collision, this raises the impulse accordingly and can cause much greater damage to the edge.
When cutting wood, it is quite possible to get the tool stuck in the wood. It can easily be twisted and bent laterally as you try to dislodge it.
Only an isse with annealed steels, or really thin blades. What is critical is high pressures causing a massive stress due to focused contacts, knots, regions of twisted grain, or high localized densities due to wood rot. It takes a horrible blade to get damaged from actual working it loose, even a cheap 1/8" machete won't be bothered by that. The only time that could likely cause a problem would be if you got it right between or around a knot which locked it in tight enough so that you could actually bend the blade before the wood would just compress and let the blade go, I never have seen that happen and can't see it happening unless the blade had an annealed spine or was really thin, 1/16" machete or similar.
-Cliff
