using a furnace, gas or electric, to heat treat high carbon steel, you need it to get to 1500F and hold. unless you are heat treating thick stock, say 3/16" or more, the blades are going to be inside for 10 to 15 minutes. what is the controller going to do that you can't with a simple adjust of the gas valve or the electric power control? for the simple kiln shown that started the thread, the first thing I did was get a good digital display and monitor the temperature. I found after setting power control to max and getting the heat to 1500F, putting blade in, temp down now to 1450F, start timing, temp close to 1500F, power control to 4, steady at 1500F, 10 minutes is done, blade out and quench.
