I don't think the RC-4 has hit the streets. I know I am still waiting on my shipment.
You're going to find that the TAK is a heavier knife than the RC-4. TAK = 10.4 ounces, RC-4= 7.4 ounces. So, the RC-4 is 3/4 the weight of the TAK. Sheathing and heat treat is way different also. I like the RC-4 a lot better than the TAK but if you like a large grip then you're going to like the TAK better. If fit, finish and no questions asked warranty has any bearing, then you're going to like the RC better. If you're looking for a hard-use beater knife then you will probably like the TAK better. If price is an issue, you will like the TAK better. They are truly two separate beasts and hard to compare.![]()
RC-4 thickness is 3/16"
From the pictures, it looks like the Tak-1, RAT-5 and RAT-7 all have the same handle (with the different tang extension ont he RAT-5). Would that be accurate?
I know I have big hands and the RAT-7 handle is a perfect fit. Don't know if that helps at all.
