Get the Huntsman for the multi-purpose corkscrew. Same top side, and side tool set. The Huntsman also retains the same punch/awl/reamer (with sewing eye) and multi purpose package hook.
My Huntsman does not have "Plus" scales, so no ink pen (a 58mm Mini Champ or Signature on the keyring or in the "watch pocket" (note quotes) takes care of that), but it does have the hole for a (multi purpose) straight sewing pin behind the multi purpose corkscrew.
(pin can be used to remove slivers or thorns, or hold material for sewing ... tho to be honest, for the latter, you'll probably need more than one pin.) A repacement pin is $8 to $10 from VIC ... or you can get 250 to 1000 sewing straight pins for $6.99 or less.
The less expesive standard sewing pins are (aside from price) identical to what VIC sells.
OH!!! the sewing pins with a ball top fit, and do not obstruct the use of the corkcrew. A ball end makes it ever so much easier to remove than a flathead pin, as well. The ball top pins also come in different colors, including red, blue, and for the December Holiday carry, green.
The flat blade screwdriver of the caplifter and small flat blade on the tip of the can opener, as you know works great on philips screws.
In addition to removing bottle corks, the corkscrew also unties over-tight knots with a twist, can scrape out slivers and thorns; when used in conjunction with the splitring, locks a T shank jigsaw blade or file in place; Holds a Fire Ant
kindling and ferro rod (or fire fly
kindling if you replace the toothpick with a fire fly
fero rod. (Personally, I'd rather replace the weak grip tweezers) or one of the three Victorinox eyeglasses/electronics mini screwdrivers. (Sadly the fire ant
/fire fly
is expensive, and it can't hold the kindling and fire ant
ferro rod
AND a Vic mini screwdriver at the same time.
All the single purpose #2/3 philips on the Fieldmaster does is turn those screws.
I've carried a Huntsman every day for over 20 consecutive years (until it was misplaced or lost during my last move.I'm on my second Huntsman, now.) I never had any issues with the knife ... or the Cellidor scales.
I highly recommend te Huntsman.
