Having heard so much about the stainless and edge-holding qualities of talonite as a knife blade, I am naturally curious about the possibility of using it in a sword blade (maybe a short sword). What do you guys think? Hope I am not asking a stupid question...
I extracted the following info. from www.talonite.com
"If tool steel stays sharp for 6 - 8 hours then Talonite® will retain an edge for 12 - 14 days... ...
Superalloys were developed for applications such as super turbochargers and aircraft turbine engines. These are applications where the alloy encounters severe mechanical stressing and it must have high temperature strengths, surface stability, resistance to high temperature erosion and resistance to corrosion... ...
Talonite® specifications:
Density .30 pounds per cubic inch
Hardness Rockwell C 41 - 49
Young's Modulus 30,000,000
Ultimate tensile 190, 000
Yield @ .2% offset 118, 000
Elongation percentage 4.5
Annealing temperature 2200 - 2300 ° F
Melting point 2600 - 2700° F
Tests run with a piece of metal that is about .161" thick x .710" wide.
1. How strong is it?
I took an eighteen-inch piece and beat it hard and long against the edge of a vise. There were some impact marks but no dents, nicks or anything else.
2. Does it bend?
We took an eighteen-inch piece and clamped it in a vice and bent it about 90 degrees with just a big guy pushing on it.
3. Does it break?
It snapped at about 90 degrees.
4. Is it springy?
It springs back clean from about 80 degrees bend.
5. Hang Test
I took a piece and jammed it in the top sill of a steel door. Then I hung from it. I had both hands, one behind the other, with one hand next to the door. I weigh 222 pounds as of this morning."
History is littered with the wars which everybody knew would never happen. ~Enoch Powell, Speech to the British Conservative Party Conference, 1967~
2. Does it bend?
3. Does it break?
4. Is it springy?
5. Hang Test
