Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The "tanto" you are thinking of was invented by American maker Bob Lum (1943-2007) so Samurai, not even slightly.
Aaah what in the hell happened to the tip of those katanas!?
Did the swordsmith forget how to reforge a broken tip, or maybe that was a half-assed field repair of a broken tip?
Most of our special forces units are outfitted with the Recon 1, and swear by it.
One thing I can tell you is that tip-up designs are not as efficient in stabbing unless you've practiced and mastered the technique. Then again, the uppercut is the most difficult strike to defend against so ymmv.
Most of our special forces units are outfitted with the Recon 1, and swear by it. I always prefer listening to those who've actually used a tool rather than ones who like to speak about 200 BC tech just because it is politically correct, and the ultimate in reverse tacticool. Ask a pro then make up your own mind. One thing I can tell you is that tip-up designs are not as efficient in stabbing unless you've practiced and mastered the technique. Then again, the uppercut is the most difficult strike to defend against so ymmv.
I think you've covered every single base:
1. Make obviously false statements about the military ("Most speshull forcuz use Cold Steel Recon 1s and swear by them for actual hardcore pro use!")
2. Spout nonsensical attacks at other members ("Yall aint actually used a tool, yalls just talking about 200BC political correct reverse tacticoolity!")
3. Use terms that you don't understand (what exactly do you think 'tip-up' means, anyway?)
4. Give vague "martial arts" advice that's about as useful as nipples on a plate carrier ("You need to have practiced and mastered the technique of stabbing!" :barf
5. Claim to be giving out professional advice ("Ask a pro then make up your mind!"...thanks, tips, you really helped answer the question.)
6. Totally ignore the thread topic (So, uh...what does any of that crap have to do with the penetrating capabilities of Tantos and Spearpoints, respectively?)
Yep. Perfect score.
In terms of which type will penetrate, simply draw an outline around the two profiles superimposed on each other. Which is the narrower one? Likely the better penetration.
Try it with empty pop cans, you can get a seat of the palm feel for which one might be easier. Some designs just slip right in with little pressure, others crush the can. I have no doubt you could find a good and bad one in each type of blade style. The latest variation of the American Tanto - which is largely coming out of China, go figure - uses a centered point, almost mirrored angle at the top and sharpened front edge, and possibly even a recurve. The angles look very much like a drop point with a small edge transistion.
Then there are enhancements one blade may have over another - like the Swamp Rat Camp Tramp having a sharpened tip, vs a Becker Campanion being darned blunt. Very similar profile, entirely different results. Looking at the ESEE series, I'd grind the top of the point first thing, it would significantly improve penetration without taking on the tacticool look.
Don't guess, try them out on pop cans. It is at least one consistent method and gets you results. It's better than guessing, and sure beats stabbing coconuts and breaking off a tip.
Wait, like these "tanto" points?
[youtube]8cN_Zo6AIMc[/youtube]
Have any pictures of tantos?
Does it actually carry any Asian influence at all or is it an overly-tactical looking rectangle?
... and as the advent of the formal pairing of Katana and Wakazashi came to take place (more as a status symbol than anything)...
