- Nov 26, 2018
Hey all,
Relatively new maker here looking for some advice. I heat treated a couple of 1084 kitchen knives yesterday and am seeing some strange colors on the blades after tempering.
In the past I’ve seen all sorts of colors in random places on my blades after tempering, so now I wipe ‘em down with acetone before temper to get off any oils or other surface impurities. These colors seem to be different, as they are only along the edge and follow a gradient from violet to blue... which is concerning. The rest of the blade is a nice straw color, see pics below. My process is as follows.
I hog out the profiles and rough grind in the bevels w/ a 36 grit belt. I leave the edge at .01”-.02”. Most of my grinding is done post HT, so this is all left very rough.
Harden with a MAPP gas torch and 2-brick forge. Quench in canola oil at 120-130 degrees Fahrenheit. Check for hardness with a file. Grind off the heat treat gunk with a knocked down 120 grit belt and wipe clean with acetone.
I then hang the blades from my oven rack for temper. Oven is solidly preheated to 400 degrees Fahrenheit, though my oven runs hot and the secondary thermometer I put in there reads 435 Fahrenheit. Temper twice for 2 hours with a room temp cool in between.
Did I ruin my temper at the edge? If so, how and why?
EDIT: can’t post pics apparently? Did Bladeforums changes this recently?
