I am still learning to weld, and would like some more information on how to test the strength of my welds without expensive equipment. I am using a Lincoln-Electric Weld-Pak 100, a wire feed welder that runs off of 110v. I don't have the MIG kit, yet anyway, so I am stuck doing flux core welds for now.
The latest test sample I welded up was a piece of 1" square tubing, with 1/16 wall thickness. I cut two 1' sections, and welded them back together. I then tried my best to break them apart. First I stuck them in my vice and tried to break the weld that way. Well, the vice is bolted to my workbench top, an old 2 x 6 plank. All I was able to do was rip the vice out, and split the board apart. Then I decided to wedge the tubing between the floor joists, and some other tubing bolted to the joists. Well I was able to hold myself up and support all my weight without breaking the weld.
I am out of ideas on how to insure that my welds are as strong as they could be. Is there anything else that I can try to test out the strength of my welds? Have these tests shown that they are strong enough, or should I test further?
Thanks in advance.
Thanks in advance.
